Extreme PSI 16g install kit
Those are the TC or turbochargers.com install kit. I don't think it's worth it at all. If you have a FMIC (side to side), the J pipe won't work. The oil drain line is a contraption that I also wouldn't consider putting on my car. Just oval out the flange holes on the T-25 drain pipe. The only thing that I ended up using in my kit was the oil feed line which is fine, but a feed line with a banjo bolt fitting would be more ideal and you can get those for under $60.
So all in all, the only things I found useful in the kit are the feed line and the copper washers and gaskets. Certainly not worth over $150 IMO.
If you are running a fmic I would get the extremepsi stainless J pipe that you can configure any way you'd like, then find a better oil feed line, oval out the original drain pipe bolt holes to match the 16g/14b and pick up the random gaskets and washers from the dealer. May seem like more of a hassle, but it will turn out better in the end.
thanks house, maybe I will just got that route. I was pointed toward an oil feed line on ebay which looks good and it is in-expensive. Im not running a FMIC and dont plan to very soon.
Thanks for the input.
