Exhuast wrap
Not sure what you mean by freeing up space as both units do not take up much space. With a simple clean up, they can look quite nice while keeping under hood temps in check and protecting components such as the alternator. However, if you are looking for an alternative, I may suggest a manifold blanket instead of wrapping it. Here is a popular blanket designed to fit the OEM style manifold:
http://www.ebay.com/itm/like/291477675240?lpid=82&chn=ps&ul_noapp=true
Not sure what you mean by freeing up space as both units do not take up much space. With a simple clean up, they can look quite nice while keeping under hood temps in check while protecting components such as the alternator. However, if you are looking for an alternative, I may suggest a manifold blanket instead of wrapping it. Here is a popular blanket designed to fit the OEM style manifold:
I did go take a close look, and the stock heat shield really doesn't take up that much room. However, I really like the look of that manifold blanket. Anyone run one of these for a period of time, and have it last? I have heard the claims of faster spool, ect... I am woundering more if it keeps under hood temps down more than the stock shield, while not falling apart?
I have had mine for over a year on an HX35 running in some really hot conditions. Still in great condition. Mine actually has a provision for an external wastegate off the manifold as well.
I have not installed mine yet, as I will wait to install the FP exhaust manifold. I have seen multiple members run this particular blanket with great success. I do not know if there is an apples-apples comparison as many use the blanket for the FP manifold which, does not have provisions to mount the OEM heat shielding. Since you are interested in swapping it out, perhaps you may be able to report on this. All you would need is an infrared thermometer and take readings under various conditions. Don't forget the lower shielding is just as important as the upper piece.
Here is another member review of the blanket:
http://www.dsmtuners.com/threads/gstwithpsis-galant-vr4-1837-2000.482807/page-3#post-153530016
I have the FP manifold blanket, The ties broke first time attempting to install so I just run it without them and tuck it on there as best I can, There is a huge difference between it being on and off.
I am using an FP manifold and I honestly think they are the same thing (the FP blanket and the ebay one) They look identical, down to the tie system.
Yep, a year later and my blanket is still holding up great. I've probably had it on and off the car half a dozen times or more, and it's still in great shape. I figured taking it on and off would trash it, but it's a solid piece.
Each time I remove it, I spray it with a new coat of VHT Flameproof paint. It keeps it looking brand new: http://www.dsmtuners.com/threads/gstwithpsis-galant-vr4-1837-2000.482807/page-6#post-153588586
It looks good, and does an awesome job at keeping under hood temps in check. It's much more effective than any heat shield you could put in its place. I'd highly recommend these.
The blankets great, I was skeptical of spending the $100 for one but well worth it. The biggest thing I noticed after installing the blanket was how much slower my idle coolant temps increased waiting at lights. Since the blanket wraps under the manifold it shields that water pipe that runs the length of the engine block from heat soaking.
This was after I had already ceramic coated my manifold...
I just swapped turbo's again this weekend and kept my blanket off and even after a short drive this evening I cannot get anywhere near my manifold, with the blanket on I could still get near it, even touch the blanket with my hand after it sitting for a few minutes.
I was skeptical like Gofer, Didn't think it was worth it but after doing research I decided to give it a shot, Now I think it's ridiculous NOT to have some sort of heat protection.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
