thermal wrap
It's been said to cause premature cracking on tubular manifolds....
Profile says your on a 16g....just get a cast FP manifold, best bang for your buck and damn near impossible to crack
Short answer: Yes. Wrap is harder on the manifold.
I'm not a fan of tubular manifolds to begin with, they just don't have the longevity and do not hold up to the heat cycling. I contemplated using wrap a while back and after a bunch of research decided against it. I've been running the Turbonetics T3 cast manifold for like 7 years now. I sent it out to Jethot to be thermally coated and its held up exceptionally well. Performs well and still looks new. It ran like $300ish but well worth it and much better than header wrap IMO.
No, crappy welds, corrosion, and heat cause manifolds to crack.
I'm guessing the heat trapped by the exhaust wrap is different than the heat you're talking about.WTF
OP, higher temps will cause premature failure of any metal. The more metal is heated, the more brittle it becomes.
Wrap a manifold, leave it on your desk for a few years and see if it cracks. Bet it wont. :rolleyes:
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
