exhaust manifold
corey smith
3
Mar 24, 2015
Jacksonville, Florida
How the hell would i get this bolt out? Not enough room to clear it by pulling it up.
Vice grips, or drop the turbo. I don't remember if there are enough threads at the top to try the double nut method (put two nuts on there, tighten them together, and then try turning the bottom one). Most people replace that stud with another turbo-manifold bolt to make removing the manifold easier in the future.
Thanks im going to go try that now. And ive purchased new bolts not going to run into the same problem again.
Did the bolt break from torque? Are you able to push the manifold back down flush with the turbo?If you can do that, maybe you'll be able to pull the manifold away from the head and lift up from there.
I wasnt able to use the two bolt method. I just got the manifold back flush with the turbo im going to try that now.
