Devilsfutbol17
- 407
- 48
- Jul 27, 2007
Bellingham,
Washington
I have a 90 tsi awd and its stock except a aftermarket boost gauge and i have a pocketlogger setup. My problem begins with the boost, I am not getting any at all. So I checked for leaks with a tester and found one at the throttle body and thats all that i could find. I then heard that I should check to see if I am leaking exhaust gas from my manifold. Turns out that the two top right holes and the bottom right hole in the head is stripped. I was then advised to try and use jb weld, that did not work. So I found that I should try and use a helicoil, but from what I have read, I have to drill out the hole first. Drilling out the bottom right hole and using the helicoil seems impossible because of the motor mount sticking out in front of the head. Could anybody give me some advice as to how I should solve this problem. thanks
