Exhaust Manifold Gasket Port Size Effects
bdidhe99
Mar 16, 2011
Banks, Oregon
I have been searching through the threads and dont seem to see and answer to my questions...
Stock 90 Talon Tsi
Replacing a cracked exhaust manifold and realize the port size on the gasket is bigger than the port sizes on the block and manifold.
I have ordered several different gaskets and they all are bigger than the port sizes on the block and manifold
Is this a problem?? What long term effects will this have??
Your feedback is appreciated!!
This depend how much bigger the gasket is?
The gaskets are usually a tiny bit bigger than the ports, you could use this as a stencil to port you new manifold.
If you are not sure, post a pic of the gasket and sufaces.
