exhaust manifold and o2 dump
megst98
Apr 26, 2005
Mahopac, New York
I was wondering if the DN Performance stainless steel exhaust manifold was a wise choice. I originally got the SBR manifold but they sent me one for an external wastegate mount. I also purchased the SBR O2 housing with dump to atmosphere. Would these two upgrades be good with an evo III big 16g upgrade (internally gated)...... or if there are any other suggestions please let me know... thanks.:dsm:
I would just keep the SBR set up for an external and just bolt a cap on the wastegate runner for now. If you ever decide to run an external you will already be set up on the manifold side.
Seth
Even if you keep the manifold you have, you can still run an O2 housing designed to dump an internally wastegated turbo.
When you cap the open flange on the manifold where an external gate would mount, you essentially have a stock style manifold. Then you can run any O2 housing you want designed to work with the internally gated E316G.
Seth
If you purchased this manifold then you are in business. http://www.slowboyracing.com/more.php?id=1891&
It should come capped off so that you could run an external wastegate or not. That is why this piece is so freakin sweet. It kills two birds with one stone. If you ordered it ported then when you get your pieces, your good to go for installation. If not, then I would strongly suggest porting out the turbine housing and the manifold. You will eliminate most of the chance getting boost creep if you do.
