Exhaust Leak on N/T
David24
May 5, 2013
Vancouver, Washington
I have a '95 Eclipse RS. Not sure what the engine is, I think it's the 420a? Non-Turbo, anyhow I put new headers in my car (and down pipe) and everything lined up correctly except where the manifold and down pipe meet. It's a sleeve type fitting where the pipe from the manifold fits inside the bottom down pipe so I thought it wouldn't need a gasket if I tightened up the bolts nice and snug. But come to find out there is a gap in the front and yes it leaks. I circled it in yellow in both pics
So am I going to have to basically redo the installation and tweak it to see if it fits in or is there something I can use to seal up that leak like exhaust cement? Is there some sort of gasket for it that I need? I've been searching the net for another similar problem someone else may have had with no luck. The car runs fine and sounds good with them but I know that it's not supposed to be leaking like that. BTW they are Megan Racing brand.
I would just use a exhaust clamp as shown in the 1st post simplest way I no of, u pick one up at your local auto parts store for a few bucks, just make sure you no the size/diameter of your exhaust, so you get the rite size clamp
ill try to see what a clamp will do. a guy i work with said i should get it welded but then if i ever had to take it out id be stuck. and now i have a check engine light on. would a exhaust leak throw a code? it is right by the o2 sensor (seen in 2nd pic)
thanks for the replies guys.
If your O2 sensor is behind the leak it most likely will throw a code. SO just try the clamps get couple and see how that works for you. Sometimes the exhaust will still leak with the clamps. So just be prepared.
Definitely just get an exhaust clamp because my shop teacher just did a quick fix and put high temp silicone around it to seal it. So now when I ever want to take it apart, I am going to have to break the silicone.
