- Thread starter
- #26
megadan
- 139
- 1
- Dec 5, 2004
montreal,
ok I installed the new O2 (denso like the old) and I can clearly see that one works! So that means I got a bad O2 for about 1 year. I bought the old one from oxygensensors.com and it came right to me defect. As he was new, I was pretty sure it was something else that was shooting my O2 sensor to 0.02V.
The moral to keep in mind... A new thing doesn't mean it work!
Now my O2 oscillate but I STILL HAVE MY PROBLEM.
The wot run seems to be fine. But my mid throttle runs make a lot of knock retard around 5 degree.
Here my new logs, you can now see that my o2 is fine compare to the previous runs in the post.
Just so you know, my spark plugs are BPR6EY.
All bearing are chipped like they missed oil. The thrust bearing is the worst. It destroyed one thrust side of the crank. What happened!!! The crank was walking because of that. When I opened the Main Thrust, the bearings were 1/4 turn off so it is impossible for oil to go by the holes in the bearing. All others bearing were in place but chipped. Now I guess the crank is scrap. I'm going to rebuild it but I want to understant why It happen so it won't occur again. Can anyone help me? Pics will follow later.
He already has a 6 bolt swap.
