exhaust gaskets are not oem
TJ Donahoo
Nov 24, 2014
Crystal River, Florida
I was having some smoking issues with my 95 gst. So today I tore apart the exhaust manifold and removed the turbo. There was oil all through out the turbo and shaft play. Lucky I savet it before the compressor turbine and exhaust turbine did any damage. But while taking it apart noticed that the downpipe gasket was cracked and the gasket between the manifold and turbo were cracked. I looked up new ones and the ones they say go to that car are not it. Oem looks square on the Down pipe with the o2 sensor. Mine are triangular. Is there anyway to find out where I can get these gaskets ? It's a td06 20g I know that's not stock... but it's what Came with the car.
After hours of searching last night I found out that the greddy turbos have a triangular gasket. So for anyone looking for one search for Greddy inlet or outlet gasket and you will find them. Only down fall is they are 20$ a piece not including shipping.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
