EVO3 16g owners
ive been under the impression that anything under 20psi will creep to 20-22psi, but if you are running 20psi+ then you are all good in the creep department. My small 16g used to creep horribly until i bought a bullseye housing witha 38mm internal gate. it holds boost fine now. It even drops of a little in the upper rpm's...
danny
Just thought id give an update.I went ahead and ported the wastegate area like crazy and it worked good for a few days and yesterday i blew a hole in the turbine housing because I ported it to far.Just wanted to warn people porting to fix creep not to go to far.I luckily know a welder who was able to fix it for me.
Moderately ported, external dump 2.5" O2, 3" exhaust, no cat.... creeps to 22-24psi. Set at 18psi. Boost spike is completely gone after the porting, still ports.
  • For sale 1g 1g 90-91 fiberglass hood
    Got this hood new in 1999. While it was fresh I reinforced the fiberglass webbing on the bottom...
