evo3 16g not a direct bolt on in a 1g?
Elight
62
Feb 28, 2004
Winslow, Indiana
I just got my sbr evo3 16g in and I go out and start to put it on my car and everthing is going fine untill i get to the oil lines. The little banjo fittings are too small. I was under the impression that a 16g bolted right onto a 1g. The only thing I can think of is the fact that I had a 13g instead of a 14b cause my cars an auto. I guess I'm going to half to get new oil lines.
This sucks,
Corey
Physically yes, I do believe the 16g is a direct bolt in on 1g cars with a manual transmission. You do need some type of kit to make it work on an automatic. I think most shops sell what you need in some form of package to make it work with automatic cars. good luck.
i did a 14b install on a 1 g auto before and as far as i can remember i had to buy bigger lines and the banjo bolts too
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
