Evo16g Porting??
Uhh YEAH!! 365HP is a big goal for an EvoIII so you are going to need to port it! By not porting it you are neglecting yourself from maximum flow capabilities. Port the turbine housing, 02 housing, and the manifold runners. Make sure you are also running a full 3" turbo-back. To get 365hp out of the evo powered motor it might help to do some internal work; at least cams.
Porting is definately worth it IMO. It will help the spool up time noticeably and most people will agree that porting will also help to eliminate the dreaded boost creep that is associated with the evoIII. I know in my case I ported the turbo for the sole purpose of getting rid of boost creep and im glad i did.
:talon:
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
