evo wastegate actuator on 16g
DOHCAccord
Jan 9, 2006
cincinnati, Ohio
I have found that the evo4-9s have 11psi wastegate actuators, is it possible to fit them to a 16g turbo?
The design of the compressor housing and turbine housing is totally different on the Evo IV-IX turbo. I'm sure it COULD work (an actuator is an actuator) but it will take some creativity.
If you're looking for one with a stiffer spring for a little more holding power, you're wasting your time. You'll need to look into certain Garrett actuators or those made by AGP.
