evo vlll long block swap into 1g gs eclipse
turbostock
Aug 28, 2005
hagerstown, Maryland
sorry had to post it here, not allowed to where it should be. i was wondering if any one knows how or about swapping an evo vlll long block into a 1990 gs turbo eclipse. what all i will need and so on. thank you.
Would require a lot of custom work. Definitely more work then its worth. Would need new mounts, as the VIII motor is flipped 180* from ours. Definitely a lot of wiring to do, I doubt that you could use your stock ECU. Just buy a JDM longblock or one from a DSM Vendor :thumb:
