evo tranny in my tsi awd
96_AWDtalon
66
Nov 22, 2008
brookpark, Ohio
can an evo tranny bolt up to a 2g awd talon or can i only use a dsm tranny with no problems.
why would you over pay for the name EVO? Just get yours rebuilt by Jacks or TRE.
Evo 4 and on trannies WILL NOT work period. An evo3 would as it is attached to the same motor we have. I agree with pimking, get yours rebuilt by jacktrans or shep. It would end up being the same cost as finding you a evo3 tranny or another dsm tranny.
The EVO 1-3 trannies will fit a DSM, but the problem is the final drive gear ratio for the front is different. So if you blindly pop an EVO trans in your DSM, you will burn up the center diff in the unit. You have to either swap the front diff ring gear and output gear with a US ratio, or swap your rear diff with the EVOIII unit which will match the trans.
The 4-10 are a completely different animal and will not fit.
