EVO IX 560cc injectors??
I am almost positive that they are the same as evoVIII injectors, and if that is the case then they are a direct replacement. I personally have evoVIII injectors and the only thing you need to change is to use the o rings from your injectors where it mounts into the fuel rail. The evo orings are too big and will not fit into your fuel rail. Good luck
AFC 1st and then injectors. I'd say leave your stock pump in until you get a little more proficient with the AFC as to not create anymore rich conditions than you need to. Yeah EVO8 and EVO9 injectors are the same. They flow more like 600cc in the EVO9, but that's not the injector; it's electronic. The guy above said the EVO9 o-rings won;t work in your head, but mine sat in there perfectly. They're a great cheap alternative to the standard RC or PTE 550cc injectors. OEM quality ftw!
you can find them all over evolutionm.net, and you can also find them on ebay. As for the o rings i was talking about the ones where the injector goes into the fuel rail not the head. The ones that come off the evo are to big to fit into the fuel rail. The ones on the head will fit perfectly.
Blitz BOV... 3" downpipe full exhaust... looking for a cheap mbc... Gauges comming soon and dejon intake pipe on delivery.
isnt the DSMlinks expensive?
Please update your profile so everyone can see your mods.
Yes, DSMlink is more expensive than the safc. You will buy an eprom ecu (found in 95' dsm's) and then purchase DSMlink too. But if you want to really get serious about tuning, definitely consider just going straight for DSMlink and forget about the safc.
http://www.dsmtuners.com/forums/search.php?searchid=3674805
Read up on some of the safc vs. DSMlink debates and you'll see what I'm talking about.
http://www.geocities.com/chmwatson/FAQs/mbc.html
Don't buy a mbc, build your own for cheap. They work great.
AHAHA sweet ill try making one for fun. Thanx turbosax2 for the advice.
Anything else i should look at getting before i get the Evo III 16G?
http://www.dsmtuners.com/sub.php?page=2gtupgrades
Just check out the upgrade path and that will get you off to a great start and will keep your car safe and healthy. One change I would make to the upgrade path though is having a logger soon. This allows you to monitor the engine. DSMlink is a logger and a tuning device so you'll be set if you get that. If you stick with the safc you'll have to get a separate logger. You should not be turning up the boost without a logger to monitor knock. Other good things to have while tuning are a map sensor (GM and AEM are popular) and a wideband o2 sensor.
can u run evo injectors temporarily,, to get from house to shop? Or will it wash the cylinder down without an afc?
Hi there im bumping this thread cause now i heard someone tell me that the will not work and someone tell me that they will....
i need some hard facts
so again i ask
will the EVO IX 560cc injectors work fine with my '98 GST?
They are odd since they have a negative deadtime compared to stock injectors... all other injectors have a positive deadtime to my knowledge (working with DSMLINK). They will work just fine, just get new o-rings and you'll be set.
c4
They will work for a fact! I just put in some evo VIII's and the only thing you need to make sure of is that you use the orings for an eclipse not for the evo. The evo o-rings are to big and will not let it go up into the rail. Also you are going to be running pretty rich until you get the safc on there.Good luck
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
