evo 560cc injectors?
JM90gst
43
Nov 5, 2009
Centra Coast, California
How much boost can evo 560cc injectors take from a small 16g on a 1st gen? Running a rewired walbro 255, 40psi base fuel pressure, FMIC with hard pipes, a 2nd gen maf, arp head studs and a metal head gasket, with a key driver chip. Just curios on a hypothetical number on these injectors with this set up. Thanks. Trying to decide if i need to go bigger with the injectors.
I recently tried running 560s with a 255lph on a small 16g and it couldn't do 20 lbs. They were running at or right around 104% duty. That was on a 2gb with 33k miles.
It all depends on the car.
I have almost the I dentical setup. My base fuel pressure is set at 45psi though. I have ran my small 16g up to 28psi with no problem at all. I do fine tune with a safc also.
I'm planning on running evo 560's with evo 8 maf and fuel pump with a BE316G. So we'll see what it can do.
Did you have an AFPR? Your stock FPR could have been overrun causing you to run rich/causing increased duty cycle.
I was able to run ~24-25psi on the b16g at 10.8:1a/f at less than 100%idc
This was on a rewired Evo8 fuel pump and injectors, 1g auto 43psi fpr.
40psi base pressure will cause those injectors to flow a bit less, probably somewhere around 550cc. They are rated at 560cc at 43.5psi but actually tend to flow closer to 580cc at that pressure.
When I had evo8 injectors I ran 23psi on an evo3 16g but was definitely pushing them to the limit with an AFR of 10.8-11.0. Certainly differences in engine VE will affect the boost that you can run so pay more attention to the airflow numbers that are in the link a couple of posts up from here.
Those injectors will just about outflow the turbo (but wont) at 100% IDC under perfect conditions. They will let your car be quite quick and a lot of fun at 80% IDC.
This turned into a good thread for me. Thank you for all the helpful information and I hope it helps others. By all means please continue to post. I will let you know when i get it up and running.
What do you plan to tune with? A lot of people have great tunes on SAFCs and dsmchips as alternatives to dsmlink.
I'm using a Greddy E-Manage Blue with all the harnesses, map sensor, and wbo2 wired in.
You're in great shape then. I plan on using a keydriver stage 3 with a 2 step and probably a safcII for added support if necessary. I'm just going for a simple daily driver that I won't have to mess with too much once it is set. I'll be using evo 560ccs in the future as well with a 190lph rewired and shoot for a simple 11:1 afr.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
