BerettaDan
- 44
- 7
- Jun 19, 2009
Philadelphia,
Pennsylvania
So I replaced my clutch in my evo 9 installed an act lightened flywheel, hd pressure plate and a street disc. Install was straight forward everything seemed to go fine. Went to drive the car it felt different a little harder to get into gear. So I went through the clutch adjustment procedure and it seemed to help. And I installed oem oil. If I’m coming to rolling stop it’s fine it’s only after a dead stop or coming from neutral. I put all 4 wheels off the ground to check for dragging. Put it in 1st pressed in clutch pedal and reved it to limiter and it’s not dragging . What I found is if I press the clutch pedal in for about 3-4 seconds before I put it in gear it slides right in. Haven’t had a chance to bleed slave yet but dont see how air would have gotten in. Any input would be great thanks
