EVOscan Evo 8 ECU log, Help
97gst_spyder
2,262
16
Sep 1, 2008
Lakeland, Florida
I just got the car running with v7 patched for an omni power 4 bar MAP. It's starting and idling fine, imo. But as soon as I hit the gas at all it wants to die. If I hold it down a little and let the rpms grow slowly it will go to redline. This is with no load (car is in the air still). Any advice, help would be epic.
Here's some evoscan logs.
Did you have the current setup running with no issues on the stock ecu before switching? I know quite a bit goes into swapping the ecu's so there may be an issue there as well.
Sorry guys. I was up all night and all today messing with the car. We got it running fine without the TPS. Known good was not working. I went to another buddy and he tried an extra TPS he had. It worked perfectly with no adjusting. The car would not run with both MAF and TPS plugged in. It would run very well with either just not both, this was very odd.
After staring at it for awhile I just cranked it with both plugged in, cranked right up and idled at 900rpm's with an afr of 14.5-14.8. I about shit myself. Did a test run, no issues at all. Then I drove it about 50 miles home with zero issues.
My car will not run any other ROM than v7 option two, ROM ends in 715.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
