evo 8 cams in a 6bolt head?
TSIBOB
May 14, 2010
Altoona, Pennsylvania
Was wondering if evo 8 cams will work in a 1g. thank you
They will fit and work but the amount of modification it requires is not worth it. If your wanting to do them because your on a budget look into stm regrinds they run like 250.00.
From what it looks like the reason the 2g head is better is because of the flow of the intake yes? So shouldnt the same technology be in the evo 8 head? Just wondering.
Luke
No you cant use an evo head on a DSM, even if you could get it on the cams are backwards and the gears are on the wrong side. If it was possible then it would be easier and better to just swap out for an evo motor, but thats not doable either.
