Evo 510, 530 or 550s
bcjjones
509
6
Nov 3, 2011
Austin, Texas
Looked it up and everyone says something different. Dude close to town is selling some injectors off a 2003 Evo 8 and I have read the flow rate is from 510 to 530 to 550cc. I've always thought they were 550s?
Found em for cheap but only want 550s
ya 550-560cc for evo 8 my friend (i seem to recall the last set i had flow tested were all damn near 555)
enjoy the extra fuel!
What about the stock pump. Its a 190 right?
And both the pump and injectors are direct swaps from what i understand?
If you plan on putting them on your 93 non-turbo, then don't. You won't need them. Also, with bigger injectors you need a way to tune them in or you'll run so rich, the car will run like crap. You can't just throw them in and think everything will be ok.
No your stock pump is not a 190. If you're asking about the EVO8 pump, it flows about 200-205.
I own a 92 talon tsi now. Sorry need to update my profile.
I was talking ahout the evo pump, and it is a direct swap. Both the injectors and pump correct?
It is a direct swap for a 2g. Should be for a 1g as well...
