2G Evo 3 Big 16g vs Hyrbid 16g with a 20g wheel
ryancampbell98
118
40
Mar 24, 2023
Wildomar, California
What would you guys recommend? a Evo 3 big 16g or a modified 16g with a 20g compressor wheel upgrade. I ran a Evo 3 16g before and I enjoyed the spool time and power I got out of it. I got a different eclipse soth a hybrid 16g with a 20g compressor wheel. I know the 20g is more laggy but I want to make the same torque and power as I did with the Evo 3 16g (300-350hp). I want to know if it’s worth keeping the hybrid 20g setup or switching to an Evo 3 for less lag. Is it worth paying to switch turbos?
Keep what you got if its working and tune for a bite more spool up. You will want a bite more power down the line anyway as most do, so allows for a bit more room to grow but you will be restricted by the turbine housing anyway so not much more air you can get in without issues getting it out
