EVO 1 starter and clutch similarities
Tri-StarPower
Jan 26, 2006
Uh, Misawa?, Asia
Hello to all. Being new to the site, I know all forums are very informative on automotive problems and valuable information on vehicle repair and tech specs. This time, It's not on information that concerns my brother's car ( 2g 95 GSX ) but a newly aquired but somewhat dilapitated EVO 1 that I can't seem to get any feedback from elsewhere. I'm still waiting for my registration to clear on a couple of other forums for now and being as such, I'll start my first post here.
1) My starter is shot. I've already pulled it and found that it doesnt look much different then any other starter from your "run of the mill" 4g63's. I have also found once on a forum FAQ search that Evo's 1-3 use the same motor as all 2g's. If so, would a starter from a 2g do the job?
2) The clutch is toast. I'm seriously considering the ACT 2100 street kit, but not sure if a DSM clutch will bolt right up. I've done a clutch job on a Skyline GTS-4 not long ago and that was a pain. I've done a job in the past on a VW golf and learned that by removing all connecting hoses / electrical lines, removing the RF wheel (and wheel hub? ), unbolting the nearest motor mount on the transmission, the motor assembly drops and the tranny with transfer case ( in theory ) should slide off after removing all bolts around the bellhousing and disconnect the driveshaft. Has anyone done a job like this on a GSX or TSI and know how difficult it is?
Thanx in advance. :)
Okay, so I'm not having any luck so far. Maybe this will help:
Starter serial #: M1T70483 12v 3309 stamped on the back of the solenoid.
Sound like anything someone here might use?
try some uk forums, and they will close this thread if you keep bumping it, especially if you use the word bump in your post. a uk forum is all i can think of that you can try, unless the serial number is the same. you could try the factory manuals on cd and see if that serial number comes up in any of it. i know there is a difference between the fwd starter motor and the awd motor if that helps at all.
im also a noob, and I was also wondering since were on the topic of dsm's to evo's, if there is a clutch kit for 1g awd turbo, since i have a few evo parts on my car already....i know this is a old post but i dont know if i should should start a new thread or what....
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
