1 and 2g starter motors question
_97tsiawd_
149
Aug 6, 2007
camas, Washington
whats the difference/specs between a 1g and a 2g starter motor. Can a 1g be used in a 2g? This is only in reguards to the turbo engine.
Is it 5spd? Mine is an automatic... are the starters different?
Yep the are the same
REMAN STARTER FOR THESE APPLICATIONS:
DODGE 2000GTX 90-89 2.0L Canada, w/AT
DODGE COLT 90-89 1.6L FWD
DODGE COLT 91-87 2.0L w/AT
DODGE COLT 93-92 2.4L w/MT, Canada
DODGE COLT 94 2.4L w/MT
DODGE RAIDER 89-87 2.6L All
DODGE RAM-50 PICKUP 89-87 2.0L w/AT
DODGE RAM-50 PICKUP 89-87 2.6L w/AT
DODGE RAM-50 PICKUP 91-90 2.4L w/AT
DODGE RAM-50 PICKUP 93-92 2.4L Canada
DODGE RAM-50 PICKUP 93-92 2.4L USA, w/AT
EAGLE 2000 GTX 93-91 2.0L w/Turbo
EAGLE 2000 GTX 93-91 2.0L wo/Turbo, w/MT
EAGLE SUMMIT 90-89 1.6L All
EAGLE SUMMIT 93-92 2.4L Canada, w/MT
EAGLE SUMMIT 94 2.4L w/MT
EAGLE SUMMIT 96-95 2.4L USA, w/MT
EAGLE TALON 91-90 2.0L All
EAGLE TALON 94-92 2.0L w/MT
EAGLE TALON 98-95 2.0L w/Turbo, w/MT
EAGLE VISTA 91-89 2.0L Canada, w/AT
HYUNDAI ELANTRA 95-92 1.6L w/MT, Longer Nose Than 17217
HYUNDAI ELANTRA 95-93 1.8L w/MT, Longer Nose Than 17217
HYUNDAI SONATA 91-89 2.4L All
HYUNDAI SONATA 98-92 2.0L w/MT, Longer Nose Than 17217
MITSUBISHI CORDIA 86 2.0L w/AT, From 6/86
MITSUBISHI CORDIA 88-87 2.0L w/AT
MITSUBISHI ECLIPSE 90 2.0L All
MITSUBISHI ECLIPSE 91 2.0L w/Turbo, From Mid 1991
MITSUBISHI ECLIPSE 91 2.0L w/Turbo, To Mid 1991
MITSUBISHI ECLIPSE 91 2.0L wo/Turbo, w/MT, From Mid 1991
MITSUBISHI ECLIPSE 91 2.0L wo/Turbo, w/MT, To Mid 1991
MITSUBISHI ECLIPSE 94-92 2.0L AWD
MITSUBISHI ECLIPSE 94-92 2.0L FWD, w/Turbo, w/AT
MITSUBISHI ECLIPSE 94-92 2.0L FWD, w/Turbo, w/MT
MITSUBISHI ECLIPSE 94-92 2.0L FWD, wo/Turbo, w/MT
MITSUBISHI ECLIPSE 97-95 2.0L w/Turbo, w/MT
MITSUBISHI ECLIPSE 99-96 2.4L w/MT
MITSUBISHI EXPO 92 2.4L w/PMGR Starter
MITSUBISHI EXPO 96-93 2.4L w/MT
MITSUBISHI GALANT 87 2.4L PMGR Starter
MITSUBISHI GALANT 89 2.0L DOHC
MITSUBISHI GALANT 89 2.0L SOHC, w/AT
MITSUBISHI GALANT 90 2.0L DOHC, 2WD, w/MT
MITSUBISHI GALANT 90 2.0L DOHC, 4WD
MITSUBISHI GALANT 90 2.0L SOHC, w/AT, 1st Prod
MITSUBISHI GALANT 91 2.0L wo/Turbo, DOHC, w/MT
MITSUBISHI GALANT 92-91 2.0L w/Turbo
MITSUBISHI GALANT 93 2.0L w/MT
MITSUBISHI GALANT 93-92 2.0L wo/Turbo, w/MT
MITSUBISHI GALANT 97-94 2.4L w/MT
MITSUBISHI GALANT 98 2.4L w/MT, Std
MITSUBISHI MIRAGE 90-89 1.6L All
MITSUBISHI MIRAGE 91 1.6L w/MT, From Mid 1991
MITSUBISHI MIRAGE 91 1.6L w/MT, To Mid 1991
MITSUBISHI MIRAGE 92 1.6L w/MT
MITSUBISHI MONTERO 86 2.6L From 5/86
MITSUBISHI MONTERO 89-87 2.6L All
MITSUBISHI MONTERO SPORT 97 2.4L All
MITSUBISHI PICKUP 89-87 2.0L w/AT
MITSUBISHI PICKUP 89-87 2.6L All
MITSUBISHI PICKUP 91-90 2.4L w/AT
MITSUBISHI PICKUP 96-92 2.4L w/AT
MITSUBISHI TREDIA 86 2.0L w/AT, From 6/86
MITSUBISHI TREDIA 88-87 2.0L w/AT
MITSUBISHI VAN 90-87 2.4L All
PLYMOUTH COLT 90-89 1.6L FWD
PLYMOUTH COLT 91-87 2.0L w/AT
PLYMOUTH COLT 93-92 2.4L w/MT, Canada
PLYMOUTH COLT 94 2.4L w/MT
PLYMOUTH LASER 91-90 2.0L All
PLYMOUTH LASER 94-92 2.0L w/MT
Ok but the thing is, mine isnt lining up. I have a 2g starter on a 1g tranny/TC. But the starter wont engage the TC, it just spins. I just put a 6bolt into my 97 and was re-using as much as I could, so I used the starter I had, a 7bolt. ???????
You make something wrong i have 1990 awd tranny with 2G fwd strarter everything go fine.
Just you make something wrong or your starter it's not working.
have ## starter tested, make sure the gear is moving out when engaged. sometimes the motor will spin, but it may not be pulling the gear out .
Yes just remove the starter and take your car battery out of the car more easy for you.
And connect the negative wire (ground) to the battery (-) and the positive wire to the batery (+) And you will se if it's working or now.
there is a difference between the awd and fwd starters (flywheels are different sizes) and i believe the auto and 5spd's are different two
the reason why it just spins is because ## using a fwd starter on a awd. the flywheels are different sizes fwd(11inch) and awd(10.5). .he half is enough to not engage at all
is your car fwd? It sounds like you used an awd six bolt flywheel in a fwd transmission.
The awd six bolt flywheel has a slightly smaller outer diameter. This means that the positioning of the bell housing has the starter too far to the outside, and the starter teeth will not engage the outer ring gear of the too small awd six bolt flywheel.
Count the teeth of the flywheel ring gear. 110 is fwd. 106 is awd. These numbers are the same for 1g and 2g.
Here's a picture of the difference. I chalked on my workbench "FWD" on the left and "AWD" on the right. Notice the way the ring gear is set differently? The AWD ring gear is in the middle so to speak, while the FWD ring gear is closer to the top.
Here's another picture of an upper view, still fwd on the left and awd on the right.
If you have a wokring starter and a broken starter, I'm pretty sure you can take the pieces off the working one and replace the worn out pieces on the broken one. I did this with nearly new starter from my 94 Diamante, parts car. Brush assembly and solenoid are identical. Cost me zero and it has worked flawleesly since then. I think Mitsubishi only made a few variations of the same starter in the 90's.
