brakes and there similarities
crasher28
Sep 20, 2009
earth, Central America
I am planning to put drilled and slotted brake rotors in my 93 Talon DL. I was wondering if anyone knows weither or not they are the same for the TSI AWD aswell?
The 93 and 94 tsi cars had the big brakes on the front, wich are not the same as what your cars has. If you got the dual piston calipers you could use the tsi rotors and pads but I would just get rotors for a fwd.
sounds like a good oppurtunity to buy the larger calipers so you can use the better rotors-larger rotors=windshield face plant for unsuspecting passengers!
Well thank you very much for the advice but since my wife is the normal passenger and i don't like sleeping on the couch i'll keep the braking to a minimum. The reason i asked is my brother owns a 1990 tsi awd and we were looking to see if we could purchase the same rotors from the same place or if we had to get different sizes.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
