Is there another way to bleed brakes?
Ok there are 2 ways to handle this. 1. go to napa and buy easy out taps they are pretty cheap and will be useful in the future. Get the good ones that don't break. You can easily pull out the bleeder valve with them.. 2. remove your caliper and rotate it until the brake line is above the bleeder screw, and slightly crack open the line and let the system gravity bleed itself. Make sure that the master cylinder cap is off when doing opt 2. It may work, it did on my 1g on the rear and i have a great feeling pedal and the car stops great too...
