Archer Fabrications
- 9,719
- 707
- May 9, 2011
Scottsdale,
Arizona
okay so im doing an evap removal and while i was at it i decided to do a write up, this is my first time doing an evap removal so any help would be appreciated, but i took pictures along the way. i have so far removed the evap canister, but all the lines leading into the car. im not sure what to do with them, also which solinoids i am able to remove. i am not doing an EGR delete YET but that will be down the road. right now i just wanna get these lines that were attached to the canister gone, also i already plugged the throttlebody lines going to what ever solinoid that was. im guessing im able to unplug that. i plan on leaving the gas tank pressure line hanging down, (not sure which one it is though).. here are some pix of thus far.
(sorry for the pix being sideways)
1st pic: evap canister
2nd pic: to take off the bracket there are two 12mm bolts one on the otherside of my hand also
3rd: unplug the headlight
4th unplug the connector on the bottom left side of the canister
5th: pull off the 2 hard lines from the evap canister
6th: im not even sure which line is which, but i am told one of these needs to be plugged at the source and one left to atmosphere (i think one of these leads to the fule tank someone correct me though please)
then its out! next im not sure where to trace everything back to the source to plug off stuff. this is kind of where i am stuck and help is appreciated.
7th pic: im prettty sure these are the lines needed to be plugged on the throttlebody. so i did that. (hope im right)
8th im not sure if where i am pointing needs removed, i think thats apart of the EGR (correct me please) im not sure if these need capping off or if i am good to go already.
9th pic, im sure this is the solinoid i need to unplug and delete. (which solinoid is this?)
this is where i have stopped and dont really know how much farther i need to go or what to do next. help is appreciated.
