2G Evap canister looks good ?
Dsmj89
3,249
14
Nov 11, 2008
Miami, Florida
I went under my battery today to look over to see if i had any leaking vac lines and surely there were 2 unplugged.
I would appreciate if from the pic anyone can tell if the vac lines look properly in place ?
The red arrow shows the hose that goes from the little can-like looking thing to the intake pipe and the blue arrow shows a nipple on the can where it was blocked off, and it said air on that side so i unplugged it and ran a hose vented for now.
I want to know if the blue arrow is supposed to be vented or recirculated ?
Thanks for any help.
The blue arrow hose is supposed to be recirculated (check for plugged hole in your intake, or maybe even just a hole!). Good catch on those vacuum leaks! :rocks:
Yeah Jose theres still 4 nipples on the 2g TB right? Well one of them is capped off..I tried finding your thread but the new layout is getting used to..So no picture for you...Ok so I looked in your photo's, I zoomed in and only saw 3 lines coming out...
Thanks guys.
Bud yes there are 3 lines coming out from a little can that hangs onto the actual big canister, and from that little can there are 3 vac lines that run from there to i believe is the back of the intalke mani.
2 of the 3 that run from the little can were unplugged so i plugged them back in.
My main concern is the blue and red arrows.
Today i already recirced the red arrow, now my concern is towards the blue arrow, the nipple that sits on top of the BIG canister, do i leave that hose venting or do i recirc, cap it off ?
Help please guys. Thanks.
You should be able to find the vacuum diagram on the underside of the hood. It would be correct for that vehicle. Given that is the hood is the orginal one.
