2G Need help figuring out evap canister lines for CEL/emissions
Talyn
443
19
Jun 10, 2012
Pittsburgh, Pennsylvania
Basically most of my emissions was already disabled when I bought the car, So I don't have the factory hoses to look at, I did have no CEL, but then when I put a new clutch in, I decided to 86 the evap canister to get some more useless clutter out of my engine bay, thinking that if I left the solenoid in it wouldn't set my CEL, well it did. And now I am trying to figure out the routing of the vac lines for it, and frankly there are too many for diagrams to help me much, I did manage to figure out which port the fuel line went to, but that's pretty much it. Have been trying to find pictures of how things are setup, but haven't been able to find anything good enough.
Vac ports are Circled, in different colors so someone can specify what goes where..
I found the information that you are looking for by doing a search on Google. I typed 1996 eagle talon vacuum line diagram. Look for the results found here on DSM tuners page. It's at the top of the page when you search. There's 4 listing matching that search. Look at the one titled vacuum line hose/ diagram. Not sure if you have seen this or not yet. I have a 1g so mine is a little different but this is from the same site I used to replace all my vacuum lines. Then I removed most afterwords. The ones your wanting to replace I removed but I have a 1g so far so good. Also look on VFAQ.COM if your not aware of this site it's very informative. I hope I have been of some help. Also I have diagram under the hood of my car, would think your would to unless it's been removed.
Everything you need to know about DSM vacuum diagrams. Including the corrections.
http://www.dsmtuners.com/forums/art...-speed-shop-vacuum-diagram-removal-1g-2g.html
No, it isn't. It doesn't show the EVAP canister so I am still only guessing at the 2nd port on that going to atmosphere, and it doesn't say if the really wide port on the control valve goes to atmosphere, presumably it would since it doesn't show anything attached, but I would rather be certain, I need my car back on the road in 3 weeks time, which doesn't leave much room for error dealing with emissions crap. Already stuck waiting on a new fuel pressure control solenoid...
