Eprom ECU
just2asian
388
Feb 13, 2006
Stow, Ohio
ok, I know this has probably been answered before, but I did a search and couldn't find it. Does a AWD eprom ecu work in a front wheel drive? Also does it differ between a Automatic and a Manual? Are they interchangble?
Yes, an AWD works in a FWD. The only difference is the AWD doesnt have the speed govenor. In a 2g, I dont think theres any difference between an auto and a manaul, both run 450cc injectors. In a 1g automatics use 390cc.
On a 1g there is because auto 1g turbo's have 390cc injectors and 1g manual turbo's have 450cc injectors. The transmission is run off a TCU that controls it so that's the only difference on 1g's. 2g's are the same.
The only other thing I can think of is I know on 1g's automatic, that the ECU retards the timing durring shifting. Don't know if they do on 2g's, but I've seen chips and ECU's interchanged between them without any problems.
