Engines out...Got issue's
stace
86
16
May 27, 2008
Belleville, ON, Canada
Hi My name is Jason..I have a 90'awdtsi...
I just finished pulling out the engine..and I could not get the passenger side drive shaft out so I dicided to push the tranny away from the block and just pull the block..
Well it worked but I'm definatly taking the tranny out and there going back in together!
Any way, When the engine was bolted to the ttranny, I rotated the crank by hand, and it seemed to bind at one spot, but not enough to stop it. It apperantly ran before I got it. all he did was loose the timing belt.\
So after a few hours , the engine was out and I found that a nub on the clutch pressure plate was hitting the tranny bellhousing casing.
I also noticed that the old owner had the engine and tranny apart before.
and the sheet metal between the block and the tranny, didnt match the starter so he cut it.
Unnfortunatly I cant show u the pic of the pressure plate , buts its wore on one of the nubs.
any ideas why?? I guess I can grinde the housing to clear the pressure plate..If the new pressure plate hits it.
PS how do you separate the axle from the tranny? I cant get anything in there to pry.
I had the same problem with the pressure plate "nubs" hitting the bellhousing on my Competition clutch when I installed it. I took a die grinder and clearanced the rib in the trans and have had no problems since. The nubs simply stuck out further than the ACT 2600 I had in there before.
To pop the axle out I use a crowbar and just give it a quick pop between the case and the axle cup.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
