Engine redlines upon startup
Austingrace24
60
Feb 15, 2012
Traverse city, Michigan
ok i just did a motor swap my old 420a blew up so i put another in ai finally got it to fire up and it goes straight to red line what would cuase this? i really need this car to run its my daily driver
A high idle could be a lot of things. Check that the throttle cable isnt too tight. It can keep the throttle plate open if it is. You can adjust the idle with the biss screw on top of the throttle body. Also make sure you dont have any vacuum leaks anywhere.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
