Engine Rebuild kit, and a little more!
95dsmracer95
39
Feb 14, 2005
Azle, Texas
Where can I find a engine rebuild kit, I want to change all gaskets, seals, and everything I can, to make the 95 eclipse below handle the power I'm going to put into it?
Eclipse is 2.0 DHOC Non-Turbo!!!
I also need to find cams, cam gears, oil pan, window shield washer tank, radaitor resivoir, dimming switch for speedometer.
For looks headlights, taillights, corner lights, rollbar kit (4 point I guess, thats inside the car, and must have half of it with plating to bolt down nos tanks, and C02 tanks!)
I also need a custom speakerbox made from fiberglass to handle 4 12" subs 800 watts max each, 3200 watts total, 2 amps, 4 power caps. That must fit in the hatch area! :D
And nothing from Ebay either! :)
Exileracing.com, HowellAutomotive.com, Moderperformance.com....id start there for the engine work ... :thumb: :dsm:
