engine problems and tach not working
al24bball
Dec 20, 2005
Tulsa, Oklahoma
I have a 94' eclipse dohc that i engine swapped a 94 1.8 talon motor with ecu and wiring harness swap and the tach isnt working and im getting misfire. i replaced the spark plugs and wires and it is still running extremely rough. please help!
You put a 1.8 into the 2.0 or the other way around? Whichever setup you have, you may need a schematic. I'd scan it to see if the pcm recognizes tach signal.
Scan and get a schematic to trace out the tach signal wire. This is assuming of course that the tach worked in the first place.
Do this and give us more information.
Good Luck
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
