engine Miss fire. Tried everything?????
91orangeGST
193
May 25, 2004
Winfield, Missouri
I have a 90 turbo laser. I was driving and the freeze plug popped out :mad: !!!(1500 miles on full rebuild) I turned off car when it got hot and when I put the new plug in and added coolant the engine starts, but only fires on a few cylinders. The number 1 plug isn't firing because its the only one wet with gas. Did a compression test and all normal. I thought maybe the computer was still tricked into thinking it had no coolant so I took the pos. cable off for 15min to reset the computer and didnt help. Any suggestions????
Kyle,
found out that all the plugs are firing bc I pulled a plug and hooked it up in every spark plug wire and when it was next to metal it sparked. Everyone. What could it be????
