Engine Knock/Tic on cold start up
jk50b
Sep 26, 2013
medina, Ohio
Okay so I have been hearing this noise since I had bought the car a few years ago. It's a Tic/Knock noise definitely coming from the head, it seems as if it has gotten louder in the past few months. But it only is loud at the initial cold start up of the car, once the car is warm the noise isn't their as much and if it is, it's very faint. Looking for ways to diagnose the problem? Thank you. (2g head, 1g bottom) (head rebuild 7000miles, upgraded 264? cams, lifter valves etc..) 97 Gsx.
Those are very strong symptoms of classic lifter tick (noise from under valve cover). This is rather common. It is not harmful to your engine. Changing the lash adjusters to revised ones (have larger 3mm port) will likely prevent the tick during warm-up. I would not look to oil additives to remedy lifter tick. Here is where I get my lifters:
http://www.ebay.com/itm/Big-Bore-LI...R4-/271171750019?_trksid=p2141725.m3641.l6368
If you would like more information, try this link from a very useful website that few use anymore:
http://members.shaw.ca/costall/1000Q/answers-problems.htm#myengineticks
Awesome! Thank you for the help.
