engine harness help, crank, cam angle missing plugs
spooln4fun
644
18
Jul 9, 2005
BELPRE, Ohio
I just installed a motor in my 2g talon tsi. My question is on the crank sensor and cam angle sensor. which plugs in to which plug since they are both triangle plugs. and on the cam angle sensor which wires go from the sensor to the plug on the car (ex red to green, or blue to blue etc) my sensor plug is broke off so will be a straight wire to the engine harness. Thanks
here is the wire diagram, i dont know what year you need so i did the one on a 95 tsi, if its the wrong car let me know ill give you the one for the right car, just look at the color codes on the chart, if you need help just hit me up
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
