96atawd
- 49
- 0
- Jul 10, 2013
Havelock,
North Carolina
What's up Tuners? I am a new guy with questions about FMIC's and cooling (radiator/coolant) issues. I have read a lot about people having engine cooling issues with fmic's, and some people preferring smic's instead, to avoid possible cooling issues, but, big smic's are hard to find nowadays, and I am worried a big smic will not offer enough charge cooling for my goal of a Evo316g. Right now I am completely stock except for Injen intake and Greddy IC pipes/bov. My first goal is to be at ~ 300 WHEEL hp with an e316g and stock 4g63 and 93 pump gas. Would a big smic (if I can find one) with good ducting be sufficient for this goal? If not...
Which fmic core design is best allowing good airflow to the radiator? Bar and plate, or tube and fin? Is the opposite better at cooling the charge air? Which brand fmic would you suggest, keeping in mind I want the best airflow to the radiator? I've read that the Greddy Fmic's allow the best airflow to the radiator, while still cooling the charge air more efficiently than any smic. Is that true? I just dont want to spend a good amount of money on a fmic and then have engine cooling issues, as I am more concerned about the engine running at the optimal temp than I am the charge being as cold as possible. I also don't want a small fmic that doesn't fill the opening of the front bumper (I will do a 2gb front conversion when I upgrade to the 16g/fmic) . So, which fmic will A) fill the 2gb front bumper opening, B) cool the charge air better than a big smic, and C) allow good airflow to the radiator? Hypothetical, if fmic "A" allows great airflow to the radiator while still cooling the charge air better than a big smic, but not as well as fmic "B", and fmic "B" cools the charge air better than both a big smic and fmic "A", but doesn't allow good airflow to the radiator, I would prefer fmic "A". Make sense? Sorry, I am picky. I just want good airflow to the radiator while still cooling the charge better than a big smic, and hopefully using most of my Greddy IC piping, if possible.
Thank You!
New DSM'er.
Thank You!
New DSM'er.
