Cooling fan issue.
Empir3 X
64
Oct 13, 2006
Centerville, Ohio
I recently installed a SBR cast manifold with a Tial Wastegate and dump tube resulting in me needing to remove the A/C fan.
After removing/unplugging the A/C fan the Cooling fan will not kick on. Is this a single circuit that i am interrupting? I did not think that was the case but i am not sure.
I tested this out by driving the car for a bit and coming home, popping the hood and observing the cooling fan not running. Car was at running temp.... it should have been on. I then carefully took the A/C fan and plugged it in by holding the shroud above the plug as opposed to where it normally would sit mounted on the radiator. As soon as i plugged the A/C fan in the cooling fan kicked right on and the car idled better and cooled a lot.
What did i not do?
I know i can buy a 10" slim fan and wire it on but i see no need and would just like to run the one. (I don't have much room at all now in that spot)
Thanks for the help.
Alex
Anything guys?
I have no clue why it is acting like this. I know of a few people that have run their 2g w/o the ac fan and the other one works just fine.
Volt test it. Make sure your getting power to it.
Im going to hard wire a switch for my fan when I get my TSi, cause I want it running cool as possible.
Test the voltage, and make sure the connector is clean.
Indian this may sound weird but do you mean ground the A/C plug? Whats strange is when i hook the A/C fan back up the cooling one works but it will not work when the a/c is unplugged.
having the same problem, when i had stock fans in the both kicked on. no hackin of the wiring. i'm putting slimmer fans in. the ac fan kicks on just fine, but i'm going to hook up a cooling fan, but, i have no power coming to the plug... any ideas. all relays are fine i switched them around just to make sure they all worked fine... any ideas?
