EMS map sensor signal wire
9 T GSX
206
40
Jan 19, 2008
St.Pete, Florida
Hopefully those with a aem can confirm this, I have started the install of the 30-1300. I have all the other wires soldered in etc,I just want to make sure that the wire that im suppose to tap into for the MAP SIGNAL wire is correct.Is it true that the wire to tap is the stock ignition check connector wire? Yellow with red stripes.
