Emission Issue
Kod
289
Mar 29, 2011
Kingston, Pennsylvania
My purge and evap solenoids tick along with the injector solenoids, but the injector sometimes the ticking is real loud, usually just moderate but also goes away for a while.
Not sure at all whats causing this, all I run is 93 + octane and changed the fuel filter.
I noticed their is a rectangle block of wires think 4 wires come out of this and its mounted on the firewall, then runs into a relay / solenoid and from their up into the purge solenoid.
Could this be the problem? If so what part is it?
I tried looking through the entire emissions diagram couldn't find it.
EDIT:
My downstream O2 sensor is shot which is what is causing all my problems.
