Eliminating the A/C
dmc67
290
3
Oct 17, 2004
Middlebourne, West Virginia
Hey I just took everything to do with my A/C out, pump, lines, radiator, and I am wondering how you guys go about plugging up the holes in the firewall right behind the battery. Also I have read that without the A/C pump the windows dont defog very well. but then again I've read where it dont really matter.
Thanks
I just left my lines covered with the plastic cap on, but I don't think you'll have any issues if you leave them open/unplugged as you don't have any pressure pushing or pulling air gas or liquid thru there.
In your air controls when you recirculate it doesn't defog as well as when you don't. I do this on every other car, so it should be the same for you. plus as you already know to defog you usually use heat, so A/C is not going to represent you a problem here.
Ok thank you very much, I think I am just gunna fill the holes up with permatex or something of the sort. reason I took everything out is b/c I have a N/T and I want as much speed/power as I can get.
