2G EGR valve?
Turbotalon25
98
Aug 30, 2008
Peoria, Illinois
Well what I wanted to know is on the egr valve can i hook the line from the inlet to the outlet, (route it back into its self)?
I took out my vac canister and blocked my vac lines on my intake. I just wanted to know if i could do the same thing to the EGR valve? I know that my stock boost gauge and vac gauges will not work now but I"m putting aftermarket ones in. :dsm:
Well what I wanted to know is on the egr valve can i hook the line from the in lit to the out lit, (rout it back ito its self) I took out my vac canister and blocked my vac lines on my intake. I just wanted to know if i could do the same thing to the egr valve? I know that my stock boost gage and vac gages will not work now but I"m putting aftermarket ones in. :dsm:
Yes, you could do that, but also bear in mind the EGR is only open during part throttle usage under a certain RPM point, I forget the specifics, and has no detrimental effect on WOT performance. However, taking it off might cause you to fail a sniffer test, depending on where you live. If you really want to get rid of it just buy an EGR block-off plate and take the valve off.
Yah I plan to get a egr block off plait (waiting for it in the mail). I just didn't know if i could do this temprarely. I live in MI right now and we have no emissions here. I'm moving to IL soon and I don't know if they have emissions there.? Another thing I noticed, there was another vac line that came up from under the Vac can (under the battery tray) I looks as though its right bye the brake lines should I cap the vac line too?
