2G EGR CEL
Blazin-Penguin
Oct 12, 2012
Manteno, Illinois
Ok so I have a problem when I open the throttle 90% or more. Right As my rpms drop, they will drop so low, that sometimes the car will stall, or recover at 250ish rpm. Also i popped a CEL for the EGR valve, so I replaced the EGR, which fixed it til about 20 miles down the road. Next I replace the IAC because the idle was surging a little. Now the problem is pretty intermittent, but still happens. especially if I am in gear and push in the clutch (I have to clutch in, and then pump the gas really quick)Im thinking its a vacuum leak, but not sure (new to turbo'd cars).
Here's a video of it.
Idle drop/surge - YouTube
turn your biss screw out a little and see what happens . your throttle body could be dirty and not enough air is getting in the engine at idle .
Do you have the BOV recirculating or open dump? I second the boost leak test as it sounds like air is making it past the maf FYI.
is the egr code still coming back . if it is then that might be your problem .i know you already changed it but there could be a problem with the vacuum supply or the egr solenoid .
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
  • For sale 2g 1997 Mitsubishi Motors Eclipse Service Manuals
    1997 Mitsubishi Motors Service Manuals $50 for the pair + shipping & paypal fees* I priced...
