turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
I've always had a b!tch of a time with really cold starts on my car, I'm talking the mornings where it's not even 12* F yet and has been even colder all night (even worse with E85.. )
PART 1:
So i started thinking about things i could do to get that initial "cold bloodednes" out of the engine and started thinking tht if i could route some warmer air into the cylinders and manifold i could cure this issue (or slightly improve my situation)
What i'm wanting to do is have the EGR open on cold cold starts so that some hot air from when it does kick up and then stalls will enter the intake mani and help keep the fuel vaporized. Now to be honest i don't know much about when the EGR is supposed to open and for how long (emissions is not really my thing) but i have seen it cause terrible stalling on cars when it sticks opens at idle and the engine is warm... But that same car will sit and warm up just fine, but i'm also not sure of the EGR's position when the warm up is happening.
So, anyone got any insight on this?
PART 2:
I finally found a part number for a block heater that goes in the freeze plug on the block for the 4g63 but, since the instructions don't give a recommended frost plug to replace with it, i was wondering if anyone has put one in and what plug you pulled to do it?
I was thinking i'd prefer it on the back of the block, but i don't know if i'd be able to get in there with something sharp or long enough to get the old plug out, and on the front of the motor i'd have to pull the turbo to install it (and deal with the cord near the exh mani) and i'd rather not do that.
Any advice on this one? I don't want to use the type that goes in your radiator hose or is just a magnet as those just seem to cheesy for me and adds more junk to the car to have to d*%k with in the morning. Winter is almost over and hopefully i move some where warmer before the next one, but just in case a block heater is a must on my list of "to do's"
PART 1:
PART 2:
i tune AEM's too) IT will actually start first kick and run for 2-3 seconds and then i do that about 5 more times before it actually stays running.. I think if i had a BISS in this TB it would probably help, but looks like i'm back to moving out of the cold (looking like FL ) so that willbe nice.. like i said, it always starts when it's warm. I will ge the block heater in either way though
