2G EDM tail light fog delete
Got a set of them recently, not a fan of the blank slot between the tail lights. I think to be technical im converting the edm lights to the jdm lights
Im not sure if anyone has done this before so I thought I would post the photos
I got out my trusty heat gun and gently heated and pryed around the lights.
If you haven't done this before I suggest doing a set of headlights first to get the feel if the hot glue prying action
Anyhoos I wanted a clean light pattern across without the blank spot
I did similar a while ago but to be a tad different i only opted to remove 1 of the blockers.
Nice job, i have asked for this to be moved into a tech article. Maybe if you want to add some small details like tool you used and where you pryed from to show others this will be helpful for people to see the smaller details of it
Thanks for posting
They still look different. The turn area is still separated so the inside squares are fully lit
I didnt take any night time pictures yet, still wiring them
I think this is the first time I’ve seen someone do this. I thought everyone bought the EDM tails for that specific look LOL
Any pictures? Curious to see how they light up
I do somewhere but perhaps on my pc as it likely was my old phone that had them. Let me see what i can find later
looks like its not on this PC so it might be on my old one that i have not backed up pics from yet onto an external hard drive
Nice writeup! I'm curious, what if you put the EDM lens on the standard USDM housing? basically swapped lenses. would that give a similar look, or even closer to the JDM look?
Thanks for sharing this!
I thought about doing this, just to make one of the corners perfect, but there would be no separation of the amber lights in the housings.
You can still tell the center lights are brighter in the fog position because of the added plastic internal reflectors
Vs factory edm
Nice write up. I opened my OEM tails a little while ago to see if I can transfer the lenses from my "JDM" lights since the corners are broken. It's a project for another day but should be able to just swap the divider onto the US housing. I used an oven in conjunction with a heat gun to open them up. Once I created a small opening I inserted a popsicle stick in between the lens and housing to prevent it from closing back up. I worked my way slowly all the way around also using an exacto blade to cut the adhesive when necessary.
  • For sale 1g 1G AWD Fuel Filler Neck
    1G AWD Fuel Filler Neck $75 + shipping & paypal fees* I would replace the rubber elbowYou...
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
