This guide covers the tail lights and related parts used on the 1995-99 Mitsubishi Eclipse.
Disclaimer: this info may not be comprehensive or exhaustive, and may contain mistakes or errors. If you see a mistake or something missing, feel free to drop a comment. :)
Note: Most of the parts shown in this guide are in used condition.
North American Tail Lights
  • Tail Light Assembly
    Includes Housing, Gasket, Bulbs (3 qty.), and M6 Washer Assembled Nuts (7 qty. per assembly)
    • Left: MR162475
    • Right: MR162476
  • Tail Light Housing
    • Left: MR154695
    • Right: MR154696
  • Gasket
    • Left: MR154701
    • Right: MR155613
  • Fasteners
    • M6 Washer Assembled Nut (7 qty. required per assembly): MS440522
European & Japanese Tail Lights
Thank you to @Mitzu Garage for providing the exterior photograph of this tail light.
    Includes Housing, Gasket, Bulbs, and M6 Washer Assembled Nuts
    • European
      • Left: MR162479
      • Right: MR162480
    • Japanese
      • Left: MR241015
      • Right: MR241016
    • European
      • Left: MR155611
      • Right: MR155612
    • Japanese
      • Left: MR221399
      • Right: MR221400
  • Gasket
    • Left: MR154701
    • Right: MR155613
  • Fasteners
    • M6 Washer Assembled Nut (7? qty. required per assembly): MS440522
Rear Reflector Garnish/End Panel
Note: I don't believe this part came with "Eclipse" lettering except when installed as OE from the factory.
  • Garnish/End Panel (Includes 7 qty. M6 Washer Assembled Nuts, but no "Eclipse" lettering?): MR162461
  • "Eclipse" lettering: MB882512
  • Fasteners:
    • M6 Washer Assembled Nut (7 qty. required): MS440502
Tail Light Interior Trim/Cover
Example part shown in gray.
  • Tail Light Covers
    • Blue:
      • Left: MR729167
      • Right: MR729169
    • Gray:
      • Left: MR729166
      • Right: MR729168
    • Beige:
      • Left: MR757842
      • Right: MR757843
Early Style Covers - 1995 Model Year Only
Example part shown in gray. This cover appears to use the same part numbers as the later style above, but they have a hole in them for the bracket and anchor.
  • Bracket (2 qty. required): MR149060
  • Net Anchor (2 qty. required): MR149057
Additional information…
These are the part numbers shown for the Right taillight gasket:
The left always shows as the MR154701 you have listed.
I’m guessing by your post / description that the gasket you show (North America) is the right side. Here’s the “other” gasket which seems to me to be the left side. It is in used condition so may not be a 100% accurate representation. The difference in the large hole near the center tail section is worth mentioning.
