ECUflash ECUFlash setup issue
Msm_exotics
4
Mar 21, 2022
Danville, Pennsylvania
Im trying to setup ecuflash on my 2g with a black box ECU MD346676 and the conversion is not working properly not sure what i missed
I'm not 100 percent certain how to check that I'm new to ecuflash first time ever using it I pulled the files from ceddymod and they were the ones for my car
I have the XML file 20550011 that's where my ECU inherited from and my internal ID is 20560009
You don't have to use whatever came on your car, but the binary and the XML must match because the addresses are different. If there is a Ceddy binary and XML that match what your ECU came with, definitely use that. Otherwise, pick one.
How do I check the binary and xml to make sure they match the tables are showing up with the wrong rpm and load
Thank you all for the reply. I did a little more digging and think I may have found my issue, have to try and find the xml files but it may be it. I have the xml files for a gst ecu but I have a 98 gsx ecu in my car.
I have to find the xmls listed here bc the link to them on this thread is unavailable anymore
Hey im not sure how to get to the latency settings how did you get your ecuflash to work with cesdymods my charts are all messed up
You have the "Big Maps" file opened up there, and the version of Ceddy mods that you are using does not include the big maps, that was an extra item that had to be paid for separately. You would want to use the regular maps on that version, or download the big maps version.
That's my stock ROM pulled up its not the big maps ceddymod file. I figured out what I did wrong I'm supposed to flash with ceddymods file not my stock one
Correct, it will also do that as I said if you didn't load up the big maps file and your trying to use it, the def file didn't match the flash on the ECU is the technical reason for it.
did you ever find the ROM files?
For the sake of clarity, you can run any of the ROMs on any of the flashable 2g ECU's, it does not have to be a GSX ROM on a GSX, you can run the GST ROM on any of the ECU's of any year of flash based 2g ECU, just pick one and stay with it and that's it.
Para mayor claridad, puedes ejecutar cualquiera de las ROM en cualquiera de las ECU 2G flasheables, no tiene que ser una ROM Gsx en una Gsx, puedes ejecutar la ROM Gst en cualquiera de las ECU de cualquier año de ECU 2G basada en flash, solo elige una y quédate con ella y eso es todo
I have gst ROM can I use it on gsx?
Yes, you could, although the ecuflash modded file that was used was from a Gst, there really would be no advantage to trying to use a Gsx file, and it would need defined for mods if you want to run a modded program, otherwise if you just wanted to flash a Gsx file to a Gst ecu and leave it stock, sure you could.
Sí, podrías, aunque el archivo modificado ecuflash que se usó era de un Gst, realmente no habría ninguna ventaja en intentar usar un archivo Gsx, y necesitaría estar definido para mods si quieres ejecutar un programa modificado, de lo contrario, si solo quisieras flashear un archivo Gsx a una ecu Gst y dejarlo original, claro que podrías.
Genial, ahora puedo usar el archivo de modificación GST Ceddy en GSX. No pude encontrar el archivo GSX Ceddy MD346676 en ningún lado, solo MD346675, que es para GST.
Great, now I can use the GST Ceddy mod file on GSX. I couldn't find the GSX Ceddy file MD346676 anywhere, only MD346675 which is for GST.
I have another question, where could I get a ROM for a Galant Rallyart 2007 3.8 Mivec?
