2G ECU Wiring - trying to fix a hack job
mikejsmith1985
129
18
Dec 15, 2009
Bethel, Ohio
So here is what I’m working with:
Issue 1.1: Pin 75, wire is cut and has 3’ of wire spliced into it going nowhere.
I believe there was once a wideband installed.
Fix: remove extra wire and solder/heat shrink harness wire back together
Use a positap with fresh wires when I install a wideband.
Issue 1.2: Pin 75&76, there is a large green casing with some sort of insulation that has been taped up and spliced into pin 92 for sensor ground. There is a black and white wire in the case white wires being pins 75&76. The pictures I hope show what’s going on but I don’t really understand what all the loose wire is I pulled out of the gray tape or how to go about correcting it. Any advice?
“Issue 2”: pins 13&26 - both are ground wires about 6”-8” before the plug one wire spliced into the other and is looped and taped with electricians tape. Looks factory just want to confirm?
That looks ugly. Im sorry I can’t be of much help since I purchased a new ECU harness from OHM Racing (highly recommend) but If you haven’t already make sure you check this post out.
https://www.dsmtuners.com/threads/2g-turbo-ecu-pinout-w-wire-colors.281763/
It should help you track down where things are going.
Thanks, that is what I was using to gather the details I have so far. I wanted to do the OHM harness but my wife put the brakes on that pretty quick LOL
Thank you for the link! I should be able to have this straightened out pretty easily now.
